Greddy 18G turbo oil feed bolt?
usmc0651dns
209
Jun 3, 2010
Monticello, Kentucky
I took the turbo setup off of my car and now I can't find a bolt that looks like it would be used for the oil feed line. I wasn't paying attention when I took it out and I'm pretty sure it would have to have a hole in it for the oil to leak down through it. Problem is I couldn't find a bolt that seems like it would be the right one. Anyone have a picture of one or know where I could get a replacement?
It's a Greddy 18G with install kit. So it's whatever oil feed line that came with it. So is it just a regular bolt or does it have a hole in it?
It's the bolt that goes in the banjo fitting.
Ummm....if you put a regular bolt into there the turbo will obviously not receive oil.
You need a banjo bolt. There should be one included in the install kit.
The turbo came off when I took off the head. I guess I lost the bolt because I cant find it anywhere. Would they have that type of bolt at a hardware store or where could I pick one up at? Thanks for the help and info by the way.
Here ya go, are you feeding the oil from the head or the oil filter housing? It needs to be fed from the oil filter housing.
This isn't a Garrett- MHI turbos actually prefer low volume / low pressure feeds.
The head is fine.
