gotta question about Engine Management
loveTOspeed
Sep 5, 2007
Hill AFB, Utah
What would you suggest I use when I install my 680 injectors? I was thinking a dsm link but i'm not to sure.:talon:
:thumb: dsmlink. it's far easier to tune your car with versus a logger and a safc, though there are other possibilities...dsmlink is probably the easiest
DSMLINK is expensive if all you want to do is tune your injectors. You also must remember you are going to need an EPROM ECU, then you need to get it socketed, then you need to have a laptop or palm to run DSMLINK on. So all in all if thats the only thing you need to tune then I would just get a SAFC and be done with it. Otherwise plan on spending atleast $750 assuming you already have a laptop. If you are for sure going to do more mods later dealing with timing, logging, etc and you have the money to blow then go with the DSMLINK.
