Got her running, but have some problems!
droppedspyder
38
May 12, 2002
Pocatello, Idaho
I got the 4g64 with 63 head and turbo running. Still need a downpipe. My second o2 sensor is not hooked up, but it runs. It's quick as hell but it has a fuel cut-out at higher rpm's. It also dies if I let off the throttle around idle rpm's. Any help would be appreciated.
What all information can you give me to do this swap? IS everything pretty much a bolt off bolt on situation let me know.
referring to your car stalling, im gonna suggest that you have one or more vacuum lines not hooked up, or maybe split
K, it has been a few months since I posted on here about my car. It runs 10x's better but now it hesitates when I get on it. It pops and sputters then boosts to 7 or 9psi. Dunno, but I hope it isn't anything too bad. I am in the process of doing the ECU swap right now. I think there is a fuel pump relay I have to bypass to make it work. But other than that, I can keep right with an Automatic z28 Camaro easily if not walk on him at higher speeds.
