got any idea???
lou schmouder
271
Jun 17, 2008
dalton, Georgia
Just got throw rebuilding my 2g. Started it up and it was leaking oil from timring belt. Took a few bolts off and moved it back . Its now leaking bad right underneath the oil pump . Leaking between the middle and last rear bolts to oil pan can get a pic if it would help got any ideas??
It could be coming from a bad seal or you may have cracked the cover during installation. You probably need to start disassembling and see what you find.
I was referring to the front cover that houses the oil pump. It could be coming from the pan, there are two bolts that go in the oil pan that are shorter than all of the other bolts, if you put them in the wrong location it could leak. The short bolts go in the front of the engine directly under the front cover/oil pump.
