good 1g 2wd exhaust
Beanokid69
355
Oct 7, 2003
San Jose, California
DOES NE1 HAVE ANY SUGGESTIONS FOR A GOOD 3" OR 3.5 EXHAUST FOR MY 93 LASER RS TURBO ITS NOT AWD SO IT KINDA NARROWS IT DOWN BUT IM SEARCHING NE SUGGESTIONS? AND IM ALSO GETTING THE 4G63 STAGE 3 SHORT BLOCK ENGINE IN A FEW WEEKS SO WILL THAT EFFECT MY EXHAUST BECUASE OF NOT HAVEING A TURBO? THX
im geting a new short block because my engine has 135000 iles on it and stuff keeps goin out i already put 3g in it just fixin it so new engine rebuilding tranny im not some kid getting the biggest things possible im tryin to keep this car goin and soup it up at the same time so do go making asumptions got it
English and punctuation are your friends. :|
Also when it says it's "700HP" that means that it can support up to 700HP not that you're going to have 700hp. If you don't know much about cars/dsm's then you're going to be in for a rude awakening when you think you can just slap on a huge turbo and run 12's/11's without some mods on that car with that engine.
Get a good setup or either tell us your plans for the setup.
When you do it..
Dontbunchittogether likethisplease.
Make sure to either seperate them with a new line or either a ;.
Thank You.
I know that it most of the time means 700 capable but this one said 700 whp and a couple of engines down it said 700 capable there so that confused me go check it out www.dsmparts.com and I plan on getting awd front axels and awd tranny so im not gona have fwd very long :)
an awd chassis is way different than the fwd chassis. you just cant bolt awd parts to a fwd car. unless you plan on doing alot of cutting,welding, custom fabricating to make the rear suspension, drivetrain, axles and differential fit, it wont be possible to make a awd out of a fwd.
i was talking to shep about this and he said i just needed to find some awd front wheel axels so is he wrong?
