BigRand
- 2,181
- 32
- Nov 17, 2004
Toronto,
Got my motor built and about ready to drop it in.
Well, I finally decided to pick a fuel mangement system. Got something a lil better than the SAFC/SFMU combo, but not a standalone that I can't afford.
I"ll be using the E-mange with the Pressure sensor, ignition harness, and injector harness, and I"ll be running the E-o1 boost controller.
I'll see what happens when I get it all going with dyno numbers and all and do a small write up since there isn't too much information about it on this site.
And that was about four months ago, I have to safe for a new engine. Are you getting the Blue, Gold, or Ultimate? On Yahoo motors are a group that is just for the e-manage and you can learn allot from there even download the support tool etc. They also found a way to install new firmware without hardware modifications to make it even a little bit more functional than the Gold so as soon as mine is running again thats what I will be doing. The e-manage is about the only thing for our 420a guys that have some support and help, BC dsmlink will not work and you need a new wire harness for aem and I do not know much about the megasquirt system, but you cant go wrong with your combo.
