General Gizzmo CamFC 550 settings?
rangerguy
162
4
Dec 10, 2002
Newport, North Carolina
Anyone run this unit?
http://www.phantasmusa.com/gizzmog0924.html
Local guy here has one that ran on a 4G, but I dont see a whole lot of info? Any input? I would prefer DSM/ECM link or SAFC - but with emissions and VIN check being a concern with NC inspection law - and I really only plan to run at most 550s - AND the guy is selling it cheap. This looks to be a good option.
Thoughts?
Thanks!
I would go with link. Why are u worried about vins when you'll be dealing with the ecu? They won't really care what ecu is in it, and link will be 10x better than what looks like a sad, overpriced excuse for an safc.
Ecmlinks the one thing you can do and not even know it's been done! ;) all the others have small control boards to setup in the car somewhere. Ecmlink you just swap the chip in the ecu. Then use a USB off the obd port to a computer. But about the gizmo, I've used there ms-ibc and it worked amazing for my needs. This controller is just to manipulate the a/f by tricking the ecu's cam signal. It kinda sounds like it doesn't work if you have a non-abjustsble cam sensor. So depending on the year motor you have this may or may not work. If non it makes it a tach a shift lite and afc. Which sounds like it just lets you monitor a/f ratio, not adjust. Only if you have a adj cam sensor can you use the controller feature.
It does work for adjusting the fuel. For reference....
http://www.superstreetonline.com/how-to/engine/ssts-0664-rc-engineering-injectors/
Granted thats no the best source, but still a idea. I see your points.
I am only worried about the vin as in NC it can throw a flag in the computer and I dont want issues. This assumes I buy a used one - likely I will as this is a project on the side and funds are limited. For 100.00 I think this will work fine for my needs. But yes ECMLINK is the way I would go if I had the cash right now.....come to think of it?
