For Sale Giant for sale thread!
dacowgod
Supporting Vendor
451
280
Feb 3, 2006
Morgantown, West Virginia
So I've been working on populating my online storefront with items and so on --- A LOT of people have said they really enjoy it while others said they preferred the lists for a quick glance of what I'm selling... So here's a shot at trying to do a little of both here... If anything catches your attention feel free to search for the item on my site for more info and photos!!
www.rixracing.com
Bbk 62mm Throttle Body with Sensors 150
Accufab 75mm throttle body 175
Mishimoto Radiator with shroud and fan 200
Oem EVO 8 Tail lights 200
Coil On Plug Kit for DSM 150
Evo 8 valve cover 200
2g gauge cluster with overlay 65
Powder Coated Gold DSM Valve Cover with -10 an fittings 250
ACT 2100 Pressure Plate 125
2g throttle body with sensors 65
1g throttle body with sensors 70
ECMLink v3 GM Maf wire 50
Unorthodox Racing Aluminum Crank Pulley 40
Evo 8 / evo 9 non acd transfer case 1000
22 Spline Manual Transfer Case 150
1990 22 spline manual transmission 500
Genuine MHI Small 16g turbo 500
Good Used Saturn Alternator 50
Blox Evo 8/9 front rollstop 50
1g head - Supertech Dual Valve Springs / SS Valves 550
1g Water Neck / Thermostat Housing 35
1990 SpecificGreen Top CAS 40
XSPower Ebay T3 Exhaust Manifold and Wastegate 40
2g Alternator 40
6 bolt forward facing oil filter housing 50
DSM 68hta turbo 850
A1 Technologies 6 bolt head studs 190
6 bolt water pipe - heater core deleted 65
Kiggly HLA 120
1g non cruise cable 40
1995 Mitsubishi Eclipse GSX Roller 850
1995 Mitsubishi Eclipse GST(AWD converted) 800
1995 Mitsubishi Eclipse GSX 0
1995 GST Auto 0
45k mile 1g auto chassis 2000
EVO Roller No title LOW Miles No Rust 1800
1997 GST PARTS CAR 0
90-96 Manual Halfshaft 75
2g Punishment Racing Intercooler Kit 225
Jay Racing 1g Alternator Relocation Kit 150
Carbon Fiber EVO Armrest Cover 100
6 bolt water pipe with -16an welded fitting - illusion purple 45
Ramhorn T3 Exhaust Manifold 225
Vibrant Spark Plug Cover! 20
FIC 750cc Hi-Z Injectors 325
ID 725cc Hi-z Injectors 325
DSM 450cc Injectors 90
EVO 9 GSC S2 cams 400
1G mishimoto aluminum radiator with two fans 125
2G mishimoto aluminum radiator with shroud and fan 125
Bulfab 1G auto front cross bar 100
FP or OEM manifold blanket 75
2.5 inch upper intercooler pipe with tial flange 125
1g Knock Sensor in Excellent shape 50
Good 1995-1996 MPI relay 25
CRACKED! DSM Valve cover with -10 an fittings 100
1gGreen top CAS 35
Polished DSM valve cover with -12 weld in vent 225
Aeromotive FPR 125
1997 manual eclipse engine harness 175
Walbro 255 fuel pump 35
Pioneer Double Din CD/DVD Player 40
Sheepy 850 HP EVO8/9 Intercooler core 425
EVO 7 Tail Lights - Stanley 375
Dsm power transistor ptu 35
Brand New ETS 4" Intercooler for 2g DSM - 3" Inlet and Outlet 650
Comp Turbochargers Billet 6765 T3 Journal Bearing Turbo setup 700
GSC S3 DSM Cams 450
FP Exhaust Manifold - Brand new! 225
Brand new BSFab 3" Vband Downpipe 450
6 bolt long block with only 82000 miles on it! Bone Stock! 900
Kiggly 6 bolt Trigger wheel set w/ Sensor 150
Kiggly 6 bolt Flexplate 175
Built 1g AWD Automatic Transmission Built by Aaron Gregory - only Idle time! 4000
AFCO Dual Pass aluminum Radiator 325
1g JMFab Small Battery Kit w/ Oddessey PC680 Battery 240
Fuel Lab "Prodigy" Fuel Pump 475
Precision 6766 Turbocharger - .82 AR T3 Turbocharger (Journal bearing) 885
Large 1g Garrett FMIC 4.5" w/ 3" piping (Will support 1000 AWHP) 700
Kelford 272/272 Camshafts 450
Very low mileage Built 6 bolt short block with Arias/Manley Turbo Tuff combo 2400
Dynarc Fab catch can for 2g DSM - 8an Fittings 200
Black Tial Q 50mm BOV 185
Black "Speedster" cover for 2g Spyder 700
Stock 2g 5 Speed Manual Transmission 700
Black Tial MVS 38mm Vband wastegate with clamp 235
S90 70mm Throttle Body 200
S90 74mm Throttle Body 200
2g "Euro" Tail lights 325
2g DSM K-Sport Coilover Set 725
ARP 'L19' Head Studs for a 7 bolt 200
Brand New Precision 6870 .96AR Vband turbo 1900
Healthy built 6 bolt short block 1650
BSFab V-Band Bottom Mount Exhaust Manifold(T4 equivalent V-band) 1000
2g LSD Rear Axles - Both Sides 250
Automatic Transfer Case - 91-96 Ratio 200
2g Automatic Halfshaft with Carrier bearing 200
2g Automatic LSD Rear Differential 225
Kiggly 6 bolt in a 2g Automatic transmission kit 200
2g Precision Torque Converter 750
Built 2g Automatic Transmission 4000
3g - Revised "No Tick" Lifters 65
ARP 'L19' Head Studs for a 6 bolt 200
Remote Tuning - 'Advanced' ECUFlash 400
Remote Tuning 'Simple' - ECUFlash 300
Remote Tuning - 'Advanced" ECMLink 350
Remote Tuning - "Simple" ECMLink 250
Kelford 284/284 High Lift Cams 450
Built 1g DSM Head - Kiggly/SS Valves/Ported and Polished 850
Dynatek Arc-2 Ignition Amplifier 285
Sparktech Coil-on-Plug (Standard Version) 325
MagnaFuel 750 Mechanical Drive Electric Fuel pump 650
Black Magnus Fuel Rail 120
New Rix 2000cc Fuel Injectors 575
Recently rebuilt nt throttle body 165
Hallman MBC 50
Blacktop CAS with Frontline Fab cover 150
EVO cluster with 24551 miles 425
Fp Exhaust Manifold with Hardware 225
Punishment o2 with open dump and Tial Wastegate 325
JMfab Drag Intake Manifold 650
Tial 50mm BOV - Gold 150
ID 2000 Fuel Injectors for DSM/EVO 625
Frontline Fab 2g bolt in fuel cell 875
