getting log from palm to computer then to post?
Status
Not open for further replies.
spidy3
192
4
Jan 20, 2005
upstate, New York
I just took my first log and cant figure out how to get it onto my computer. And just to make it easier i'll ask how to post it in a thread. Lastly, I logged my run in graph form, do i need to switch it over to columns and numbers?
Thanks,
:talon: Dom
14 views and no one can give me any help/info?! Gee thanks for all the help, I guess this must not be a thread that you could get rep points for so no one posted a reply
Please don't bump your own posts. Also, some of us are not on here 24h / day so your question might not get answered right away.
The other reason you might not have received a response is because you never told anyone what logger program you are using. :thumb:
pocketlogger with palmIIIxe on an IBM computer with windows xp.
I am assuming that the logs look ok on your palm? You then need to Hotsync the palm with your computer. Next navigate to your hotsync -> username folder and locate the logs.
You did download and install the PLViewer program from the Pocketlogger website, right?
Make sure that you are running the correct Java runtime environment for the PLViewer program. Open the PLViewer program and open your logs. From there change from the graphical view of the log, to the matrix view so you can see the actual numbers. You can then export the numbers to another program or just do a print screen and post up the picture.
Hope that helps. If you need more assistance, I most likely won't be back on until Monday when I come back to work.
Status
