Gauge pod question
blackGSX2g
DSM Wiseman
3,334
88
Apr 30, 2004
Kalamazoo, Michigan
Hey, I tried searching for info on the gauge pod that goes around the instrument cluster for 2gs, but I couldn't find what I'm looking for. I was wondering if anyone who has it could tell me what depth of gauges will fit?
I've got an electric oil pressure gauge and its pretty long. I held it up to my stock gauge cluster with the bezel off and it looks like it will stick out alot. Share your experience.
Thanks
The depth issue can be dicey. I had to re-design the bulb and vacuum port setups on a VDO boost gauge, or carve up the stock gauge cover. There's quite a taper to the bottom third. I've also seen some leave the gauges sticking out some. I'd show a pic, but I've not gotten around to putting it in yet, as I've been awfully busy being lazy.
yea the depth is a little tight, i believe the autometer phantoms will fit if you cut off the studs on the backside (the mounting screw stud thingys). or leave them out a little like defiant suggested.....i might be able to take a pic of the clearance for you this afternoon if you need....
  • Wanted 1g WTB 1g eagle talon A-pillar trim.
    Looking to buy driver side A-pillar trim, with pods preferred.
    • Walnuts
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
