Gauge Illumination Problem
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I just reinstalled my Glowshift gauges after fixing the shotty wiring that the previous owner of my car had done. Yes, I know that this has been covered numerous times and yes, I searched. I have the 7 color boost and oil pressure gauges.
The ground is bolted to the chassis.
The 12v switched is tapped into the green with white line wire on the cigarette lighter.
The 12v constant is plugged in with the fuse for the cigarette lighter.
When I turn the switch for my headlights, the needle on the gauges lights up but I dont have any background color. Does anyone know where im going wrong here?
I dont need all 7 colors, white will do(in fact, these gauges are just here temporarily until I buy better quality ones).
if you have a small motorcycle battery, hook that to your leads to see if it lights. Always possible that your fuse for the cig lighter blew, or the tap is loose if it is not soddered
Neither the cigarette lighter nor and its fuse are 12V constant. I've actually run a 10ga wire from my battery in to a distribution block for all the things that I have that need 12V constant.
I use the cigarette lighter for the 12V switched stuff though.
And for ground, I use a bolt in the foot well area that I've tested for resistance to the - battery terminal.
