gas pedal free play
chavez408
1,115
Dec 13, 2003
Bay Area, California
does anyone have a picture on where am i suppose to tighten to reduce the my free play on my gas pedal?
OR if it's just you, tighten loosen up the bolts with the pedal in normal position. Pull on the cable until there is little to no slack between the bolt holes and the throttle body. Tighten down the bolts, and push on the accelerator. Go back out and make sure there is still little to no slack. If the line is too tight, then the car will idle high.
