Lambiablo
- 90
- 5
- Apr 8, 2008
Elon,
North Carolina
Hey guys,
I'm performing a small garage clean out. The following parts are just what I have put into a list at this time.
If there are other items you need feel free to ask if I have it, though most of what I have are used OEM parts. Prices don't include shipping, however prices can be flexible, I will
also work deals on multiple items. Anything listed as FREE only needs shipping covered or sent with something else.
*Unless agreed upon otherwise, buyer pays paypal fees.
Everything is in good condition unless stated otherwise.
Items located in Winston Salem, NC.
Paypal (ship) or cash (local pickup) only.
Thanks.
$075 OEM 7 bolt camshafts
$100 New Re-Man AC compressor for 2G (bolted up but never charged or used)
$020 Gauge cluster bezels (I have 2)
FREE 12" slim fan (11" fins) black
FREE 8" slim fan blue (rather warped but runs)
$015 Vibrant performance stainless weld on tip (never used)
$010 2Ga cam position sensor
$030 2G map sensor w/ universal bracket (2G guys running 1G or aftermarket manifold)
$010 1G intake manifold support brace (with hard vacuum lines)
$010 1G starter plate
$010 Misc. Motor mounts (As pictured, each)
$050 2G Instrument cluster
$010 2G Intake manifold support brace
$010 2G motor mounts (busted, good for urethane insterts)
$005 2G Fuel pump bracket
$030 2G stock air intake box
$020 2G OEM upper air intake pipe
$015 2G BOV (unmodified)
$020 Greddy aluminum hard upper pipe (only 1 piece, pictured next to fog lights)
$040 7 bolt flywheel (may need turning) ~70,000 miles
$020 Small aluminum throttle body elbow
$025 Large aluminum throttle body elbow
$030 1G fuel rail
$070 2G intake manifold
$030 EBAY stainless T3 manifold with 38mm wastegate flange
SOLD 2G Fog lights
$050 100 on ebay BLE manual timing belt tensioner
$030 Exhaust manifolds (I have 2)
SOLD Heat shield
$025 o2 Housing
$010 PAIR OEM cam gears
$050 shifter cables (95/96)
$060 1G intake manifold
$005 T3 divided gasket (never used)
$050 2G Stock 450cc injectors (black top)
$100 (~$125 typically) Brand new ARP undercut 12mm headstuds, for 6 bolt engines (never opened)
$025 Talon badged 2G airbag (from a 95 donor)
Thanks.
$030 1G fuel rail
SOLD 2G Fog lights
SOLD Heat shield
$025 o2 Housing
