daren_p
DSM Wiseman
- 4,608
- 93
- Nov 22, 2004
Newmarket,
ON_Canada
Have a couple questions about axles on my fwd. I will be running Hoosier drag radials at the track this year & was thinking about maybe swapping to a stronger axle, in the hopes I won't snap them. My first question (& think the answer is no) is can you swap 2g fwd & awd front axles (to lose the unequal length fwd axles)? Have read the shaft diameter is different at the tranny end but thought RRE only listed one Quaife for both fwd & awd....
Second question is for guys that are running upgraded axles what are you running, what kinf od power are you making & of course with what type of tire. Think my choices are pretty limited. Looks like Raxles doesn't make a "performance" axle for fwd's & the ones from DSS are ~$700 & top of the line are ~$1500. Currently the most I'll be making is around 400whp (limited by stock block), so what would be better suited to me? (really don't want to spend $1500 on axles)
