FWD Gear Oil Leak
marcman804
484
11
Mar 5, 2005
Cumberland, Virginia
I have a 2g FWD and recently I noticed my car was losing gear oil so I figured maybe it was leaking by the axle seals in the transmission. I replaced both axle seals and its still losing gear oil but I cant determine where its leaking from and it only does it when the car is being driven. Im thinking maybe the axle seal may still be the problem because I did have a tough time getting it to go in easily but I was wondering where are some good places to look without having to remove the transmission. Thanks.
I assume you've looked under the car if you've replaced the seals. There's a lot of places it can leak from but it should be obvious.
