fully built 420a turbo if you have any questions ask learned alot making this one
TeamFusion said:
Front Bumper is a Stillen, not vader :thumb:
Hey, a fellow O-towner with a Stillen bumper cover! And my GST is silver! I don't want my Stillen piece anymore, though, trying to find an OEM silver 2gb :cool:
Any of you guys have a pic of the timing side of the 420a? Removed and with out cover? I'm putting mine back together, but i started a while back and forgot a few details.
I don't have the stillen bumper anymore, changed it up and I should have some new pictures coming soon to post of the new look. So keep your stillen on :thumb: And I haven't really driven on the stage 5 clutch since my car has been in the shop for months.
I have a 97 N/T, i have just finished puttingmy engine back in, i did a complete turbo rebuild, i attempted to turn it over, but the engine wont fire up, all systems have power, started turns, everything moves perfectly, have all fluids. Every thing is working, but the coil doesn't get any power, i traced the wires back to the PCM, and no power is being sent. I con't figure out what the problem is.
I found that my alternater choke fuse is blown, i figured that was the problem, which i have yet to figure out, the reason for this is when i replace the fuse it pops. it even managed to pop a larger fuse (i know that was a bad idea, but i wanted to see of that was my power problem) so what would be the reason the fuse keeps blowing?
Check grounds, shorts, etc. throughout the wiring because something along the line is not liking what it's seeing whenever you put that fuse in there...therefore, something is not right :thumb:
Found the problem, the power wire to the alternator was grounding directly to the body of the alternator, so now thats fixed. But the coil still isn't getting any power. The ECU isn't sending power to the wires. Any ideas?
Cool, glad I could help getting part of that problem knocked out. :cool: Does the fuse still blow, or is it ok now? Is it possible that the ecu just needs to be reset, now that you have fixed that grounding problem? :confused: I don't know if you have already, but try unplugging the battery for a few minutes, and letting the ecu reset itself. Also make sure to check all your fuses once again since it's not sending any signal at all still. Well, hope I was able to help out some more, good luck :thumb:
I let the ECU reset over night, and still nothing. checked all fuses, there all good, even the one that kept blowing is good. still trying to figure out what maybe going on.
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
