For Sale Full engine build. Brand new. (6 bolt)
Geeb
384
50
Apr 6, 2016
Philadelphia, Pennsylvania
Located in Philadelphia, PA
6 bolt Shortblock. Fresh from the machine shop, decked, honed, kiggly girdle installed, line honed, oil passages smoothed and casting imperfections removed
Brand new CP pistons (coated with CBX ceramic heat coat) still in box, only opened for coating. Comes with everything brand new and unopened.
Manley H beams
Brand new Eagle steel crank
BNIB king racing bearings (crank and rods)
Built head... kiggly beehive springs titanium retainers, BNIB unopened kiggly HLA, GSC stainless steel nitride coated valves, GSC bronze valve guides, head machine work- fresh deck, o ringed (with new copper ring material, can use steel if you want), oil port mod (smoothed and bored), ported and knife edged.
I also have a brand new still packaged Mitsubishi OEM MLS headgasket that can be included if the price is good.
And a Cometic streetpro block gasket set.
And every bolt that goes in this engine I have brand new, OEM. they were all bought new from extreme psi and cost me almost 350$ alone just in bolts
I'm looking for $2100 for this setup.
Text me at 215 983 8091
