full boost but going nowhere
Nomad666
233
Sep 9, 2002
This only occurs in 4th or 5th gear. When I floor it the rpm's strart to jump from 4500 to 6500 back to 5000 and slowly continues to accelerate. Both my boost gauges (stock and aftermarket) are reading full boost(11psi). Could it be my clutch or is my tranny toast. First 3 gears are fine. They pull very hard. Thanx for your time.
Souraj M.
When I firt saw your thread I though either your car is pulling timing(i.e knock, or in your case boost leak) or you have an ignition prioblem. I had both at the same time, and Im trying to fix the leak when I get the damn time...
Andrew
