full boost at 2500 RPM????
Amazin' Wasian
Banned Member
476
4
May 7, 2004
Tulsa, Oklahoma
just like the tittle says im getting full boost around 2500 RPM? any one know why this is happening? im pretty sure my turbo is about to be dead could that be the problem? like ill just be cruising down the highway and i will constantly have 3 pounds of boost//// :toobad:
are you going off the stock boost gauge ? or an aftermarket one?
buy an aftermarket boost gauge, that should be everyone's first mod since our stock boost gauges would read the same crappy readout if a rabid monkey was slapping the needle around.
Also, what speeds were you cruising on the highway? I find that when I'm cruising around 75mph and then give is just a tiny bit of gas it starts spooling. Maybe that's what you're hearing.
