justinsprung
- 0
- May 3, 2004
Bay City,
Michigan
I'm thinking of just doing a walbro 190 pump and an A/F gauge for now.
Is there anything else that I NEED in order to make this work properly?
Will I see gains from this on my current setup?
how much boost could I run with the new fuel upgrade?
will I need an afpr when running the 190?
I really dont want to spend the money on injectors, safc, and a logging method. I just want to keep it simple and cheap for now. Maybe over the winter I will go the rest of the way.
My current setup includes a fpbigt28, an adfx smic, 2.5 inch turbo back exhaust, 2.5 upper and lower ic pipe. 1st gen bov, buschur bc set to 15 psi.
Any suggestions are greatly appreciated. Thank you in advance
