Fuel Sender bent?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
I replaced my fuel pump about a year ago and guess that I bent the fuel sender at that time. The tank doesn't read completely full when I gas up now...reads about 7/8 full.
I am looking at the prices of used ones and spending $150+ for a used one plus the pain of going back in there doesn't seem worth it.
Is there any way that I will be able to see where I bent it and straighten it? Seems like something that I am better off living with but wanted to know just in case.
Thanks
Pull out assemble and remove the screw on electrical contact on the leveler. Once separated move the leaver up and down looking at the contact resistor to make sure it is making full contact top to bottom. You will need to bend the contact slightly so the sender have full contact through it range of motion . Good luck.
Hey thanks for the tip...hope you are around in a few years when I actually get around to this! ROFL
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
