2G Fuel issue?
TheMormonFuzz
May 15, 2012
Shelby, Ohio
Car: 1998 eclipse spyder gs-t all stock 70,000mi on original motor
Info: car has been sitting in garage since 2003 we put a new fuel pump in it in 2004 and it has been sitting ever since...decided this would be the year to get it out and start enjoying it...car was completely out of gas sitting in the garage put a charger on the battery put 5gal of fuel in it to get it running...car started idles very well for and hour I drive the car 10miles to the next city over run very well...shut car off at bar...
Issue: car will not start back up fuel gauge reads no gas but there has to be at least 7gal in tank..car turns over just seems like its not getting fuel...
Question: what could have went wrong...it was running good I shut it off not it doesn't run at all?
Sorry about the posts of the same thing. I don't know why it did that
I would check first to see if you are getting fuel to your injectors. I pull them out and place them in cups and give the engine one quick turn to see if they shoot our fuel. If not I would check your fuel filter, I always tested them by trying to blow through the in side and see if you can feel coming out of the other side. Idk if this is the "proper" way to do it, but it works. Keep systematically checking fuel components all the way to fuel pump. Very possibly something could have gotten clogged.
Do you know where the fuel filter is located at on my type of car?
bottom half of the passenger side firewall.
Confirm you are/are not getting fuel to the rail by disconnecting the return line after the fuel pressure regulator and running the hose from the fpr to a bucket and crank.
Would any of you know if the sending unit it the same out of a non turbo eclipse and would work in a turbo eclipse?
First did you drain and flush the fuel tank prior to refueling it? alot of times gasoline will gum up in the tank, filter, and lines, as well as injectors. I would suggest draining the tank, remove the injectors have them professionally cleaned and tested, go up under the car and take a good look at both your feed and return fuel lines, check for damage and leaks maybe dipping your fuel pressure. At the very least replace the fuel filter, its probably all gummed up by now. Be sure to really check the fuel tank, after awhile rust can get everywhere. you could have cracked a seam in the tank, or the rubber on the filler next could be dry rot. Do you smell excessive amount of fuel around the car?
+1:thumb:
Given that fuel turns into a gum/varnish over time and you said the car ran fine for an hour or so, it may have pushed some of the gummed up crap through the lines. I suggest the aforementioned and get a fuel pressure gauge and see what it is at the fuel rail. A professional cleaning and fuel filter replacement may be in order... at least the fuel filter. Happy motoring!
Would any of you know if the sending unit is the same out of a non turbo eclipse and would work in a turbo eclipse?
I would start by pulling a fuel line at the fuel rail or fpr, have a little container ready and turn the key to on position, the pump should prime and squirt fuel. That's the first thing I would do.
I was wondering if anyone could tell me what years and models I could interchange gas tanks...I have a 98 eclipse spyder Gs-T and I have a buddy who has a tank out of a 95 eclipse Gs-T coupe and what I'm asking is if it will fit?
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
