Fuel injectors Lbs to cc per Hr.
tqmx1
667
4
Jan 17, 2007
Sacramento, California
I am looking at some 30pound per Hr. injectors and can't find a conversion chart over to CCs per Hr.
http://users.erols.com/srweiss/calcpchg.htm
tweak it until the output is 30lb/hr... aw hell, it works out to 315.3cc/min
Here is the formula
Fuel injector flow (cc/min)* = Fuel injectors flow (lb/hr) x 10.5
BTW, it's cc/min, cc/hr will be a big number (cc/min * 60)
Also, injectors are rated at different pressures. DSM static fuel pressure is kinda low compared to other cars I've worked with, you can use that flow calculator to account for that.
