InfiniteGSX
- 3,182
- 16
- Dec 10, 2002
Tijeras,
New Mexico
2GNT.com said:· What is a fuel cut defender?
A simple device actually. OBDII cars (96+ DSM's) don't like detecting postive manifold pressure (turbo). The ECU detects manifold pressure by the use of the Manifold Absolute Pressure sensor or MAP. Our cars come with a 5volt MAP sensor, on Wide Open Throttle and our cars running Naturally aspirated, the MAP gives a signal to the ECUof around 4.7volts. If it reads more than that then you are creating positive manifold pressure and the ECU flips out and starts cutting fuel and doing all kind of weird stuff. The VC1, or Fuel cut defencer simply "clamps" the voltage down to a certain voltage, hmm how about that, 4.7volts! So, your ECU stays happy and doesn't start retarding ignition and cut fuel when you go under boost.
Is this true? And if so where do I get this?
