Avionixx
- 354
- 0
- Jun 11, 2007
San Leandro,
California
Decided it's about time I sell my DSM and move on to something more modern (Evo!). It's got a quite a list of mods so hopefully you don't get bored on the scroll down
The car has just passed smog (legally!) so if sold within the next 90 days, buyer won't have to re-smog to transfer ownership and drive it.
Chassis:
269,012 miles on chassis
Engine:
Approx 2000 miles on motor
Ported intake and exhaust ports
Big bore lifters, 5 angle valve job
SI 1mm oversized nitraded valves w/ bronze valve guides
Ferrea dual springs and retainers
HKS 272/272 intake and exhaust cams w/ Fidanza adjustible cam gears
Greddy kevlar timing belt
O-ringed deck
Arias .020-over forged pistons / 8.6:1 compression ratio
Manley TurboTuff I-beam connecting rods
ARP main and head studs and rod bolts
Micropolished and balanced rotating assembly w/ Clevite bearings
Setrab oil cooler
No AC compressor or bracket (lines and condenser still there)
Runs E-85
Koyo aluminum radiator
Turbo:
Forced Performance HTA68 turbocharger
ETS 7" (3 in thick) front mount intercooler, w/ unmodified crash beam
2.5" intercooler piping powder coated gloss black
"Blow Through" setup with 3" GM MAS, 2nd gen REAL HKS SSQV blowoff valve
EVO III exhaust manifold
Evo III O2 housing, 3" turbo-back exhaust system w/ high flow cat and Magnaflow dual tip muffler
Drivetrain:
TRE Race trans (4 spider center diff w/thrust bearing upgrade, Speed Design Shift Shafts, heavy duty 3rd/4th gearset, EVO steel shift forks for 1st, 2nd, 3rd, and 4th gears)
ACT 2600 clutch w/ 11lb RRE chromoly flywheel
New shift cables
4-bolt rear diff w/LSD
Handling:
Fuzion HRI tires w/ 80% treadlife
KYB AGX adjustable shocks on all four corners w/ Eibach Pro Kit springs
Electronics:
DSM Link v.2 fully programmable engine management system w/ socketed ECU
1450cc FIC BlueMax injectors
ProSport 52mm electronic boost and oil pressure gauges
AEM UEGO wideband gauge
AEM water/alcohol injection system (currently disabled)
JVC MP3, WMA, HD Radio capable head unit
Kenwood speakers (front only, no rear speakers installed)
The Bad:
Interior and exterior not in the best condition
Driver's side door lock cylinder needs to be replaced (someone tried to pick it)
Driver's side window regulator will need to be replaced (still works, just need to guide glass up)
Pics
DSM - One World
ASKING $4500 OBO, have receipts for nearly everything. Will listen to all reasonable offers.
Chassis:
Engine:
O-ringed deck
Setrab oil cooler
Runs E-85
Turbo:
Drivetrain:
New shift cables
Handling:
Electronics:
The Bad:
Pics
DSM - One World
