Type1DSMr
- 1,116
- 164
- Jul 27, 2014
Jasper,
Indiana
I drove my car to the store about 1 mile from the house, and I notice that the front end suspension started to make a lot of noise. The noise it self sounds like something is loose as in rattling and clunking sound at very low speeds of 2 mph or greater. Needless to say I parked the car and walked home
So far I was able to jack the front end up and check the control arms, sway links, tie rods, and check the boots on the cv. Everything was nice and tight without play or rips in the boots. I replaced the most of the front suspension a couple of months ago with an alignment. I can feel the clunking in the front tires and in the steering wheel.
At this point I'm unsure what to check or what could be the problem. Any help would be greatly appreciated. Thanks
. So far I was able to jack the front end up and check the control arms, sway links, tie rods, and check the boots on the cv. Everything was nice and tight without play or rips in the boots. I replaced the most of the front suspension a couple of months ago with an alignment. I can feel the clunking in the front tires and in the steering wheel.
