Freshly Rebuilt :) Now a few Questions
2GSOCAL
34
Dec 6, 2004
San Diego, California
Ok with a fresh rebuilt engine what is a recommened safe level of boost that wouldnt stress the engine too much, right now it is stock T-25 but i got a big 16G EVOIII i need to put in. Also when i use to set the boost as low as possible with my manual boost controller it would still register as 10lbs, is that normal? Also how much would it cost to take your car to a tuner and have him professionally tune the car? And would this require a A/F controller being installed in the car? Thanks for the help...:talon:
10 pounds is about right for stock boost.
Different shops will charge differently to tune, usually around 200 an hour or so. They need something to tune with so you would need an S-AFC or something to control your fuel delivery.
Safe boost level would be determined by several factors, but you won't know until you datalog.
  • Wanted 6 bolt NT water pipe
    • chrisman287
