FP red and Punishment Racing o2 housing
shoqboom
Nov 1, 2011
San Diego, California
Well for anyone that wants to run this set up for future reference you will need to run a slim fan. Straight from punishment racing themselves.
It fits, no issues. I have a green with that setup. Hope this helps. With factory radiator the slim fan is a must.
I only need to replace the fan closest to the alternator right? and would a 12' fan do or do I need a 10'?
The drivers side fan is the AC fan. And yes, It should be the only one you need to replace with a slim fan. FAL and SPAL come highly recommended (one is certainly better, I forget which). Don't bother buying a cheap ebay fan.
Also, You might try hacking up the oem fan. You might get it to fit. I currently have a 20g with external knockoff 38mm wastegate on o2 setup and a little trimming of the AC fan bracket/shroud thing allowed it to fit.
I have it. And it fits fine I have a aluminum radiator with the stock fan no trimming. I don't have a fan in the a/c spot. I run 70/30 coolant mix w/ water wetter no issues and it left me room to remove my mvs wastegate to change springs. I have a dyno appointment saturday so i figure that will really show if i need the other fan or not.
  • Wanted 6 bolt NT water pipe
    • chrisman287
