Fp exhaust manifold bottom right bolt problem.
kaganader
161
3
Feb 23, 2009
a planet, New York
Hey guys, I have gotten the turbo manifold bolted up to the head and 3 of the 4 bolts tight on the turbo but I'm having a problem getting the bottom right bolt down on the fp exhaust manifold.
Was/is it hard for you guys to get that bottom right bolt down and tight? I can barely get my 14mm wrench on it and when I do I can only turn it 1/6 of a full rotation each time.
Its not stripped, I checked it when I took it off but that bolt is such a PITA to even work on. I will take it off again and retry it, I just got to wait till it stops raining again.
It's just hard to get to. I use a mini 14mm wrench till it's snug, then torque it with a full size 14mm wrench.
Okay thanks didn't think of using a mini wrench on it. I will try that next.
Yep...complete PITA.
I took a grinder to a 14mm box end wrench to thin it up on one side and take a little off the thickness. It works...mostly.
I love the FP manifold, but I think they could've done a bit better with that area.
I totally agree with you Calan on that. If they made that last runner up and over the 3rd runner by 1/2 inch, me and anyone with a FP manifold could just get a socket over it and call it a day.
Thank you RvlutionMtrsprt Using mini wrenches def helped me a lot. thanks for the advice!
I love Permatex stuff, i have imported a big box from USA recently !
I use it on everything subjected to hot temp ...
If you have a problem for instal one bolt, imagine for remove it after few month...
For anyone searching in the future:
Permatex Anti-seize (up to 1600* F) -
http://www.permatex.com/products/Au...ubricants/Permatex_Anti-Seize_Lubricant_a.htm
Amazon.com: Permatex 81343 Anti-Seize Lubricant 133: Automotive
Permatex Copper Anti-seize (up to 1800* F) -
http://www.permatex.com/products/Au...ts/Permatex_Copper_Anti-Seize_Lubricant_b.htm
Amazon.com: Permatex 09128 Copper Anti-Seize Lubricant - 8 Oz.: Automotive
Personally, I just use the carded tubes of the standard stuff and have never had any issues...but YMMV of course.
An old hot-rodders trick: If you can't get to a parts store, liquid Maalox will also work. ;)
Wow thanks for this info Calan!
