fp big28 offer, good? complete? too much?
Mike_GSX
125
Feb 24, 2004
Zurich, Europe
Hi, a friend of me want to buy a FP BI28.
This is a list he got from FP.
What do you think?
here is my suggestion and prices for the following items plus what you
may also need for installation:
FP Big 28 - $819.95
Port turbo - $95.00
Evo 3 Manifold - $222.50
Port Manifold - $95.00
Evo 3 O2 - $130.15
Port o2 - $95.00
650cc Injectors - $270.00
Walbro 255 Fuel Pump - $99.00
Fuel Pump Install Kit - $20.00
FP Intake Pipe - $69.00
BOV Return tube - $25.00
4" to 2.25" reducer - $36.00
4" straight coupler - $9.00
Turbine housing inlet gasket - $25.00
Turbine housing outlet gasket - $15.00
Oil Drain gasket (2) - $1.00 each
2g Oil Feed line - $65.00
Turbo to Manifold Bolts (4) - $5.55 each
Turbo to Manifold washers (8) - $1.73 each
*Total - $2128.64
Mike
Also I'm looking to about 300-max320whp.
I think that soult be realistic with a fp Big28 not?
Thanks
Mike_GSX
There are much cheaper alternatives to that, especially the porting of everything. Tell your friend he should also get a new exhaust manifold gasket if this is his first turbo job.
The FP Big28 is definitely capable of 300-320 whp, especially if its on a GST with a good tune. Be sure to order FP's 17 psi actuator as well, that has helped many people out.
