found the exhaust for my esi
tonypanda
300
Jan 18, 2011
murphysboro, Illinois
bolts.
don't you have other threads on the same topic?
appears it is the full header system so all supplied bolts will be provided and bolt her together.
only a 2" pipe though. i'd want nothing less than 2.5 if it was me.
If you look right you might find a kit for cheaper..... also the long bolts right next to the header bolt right on. Its easy to install so need to take it to a muffler shop but you might wanna have a friend help you out
this was the 1st full exhaust system i seen that comes with headers and everything
to me that seems cheap for a full exhaust...## askin for crap....i def wouldn't pay less....
i might just buy the cat back system like that one and then look for a different set of headers
there was a header setup on ebay that had good reviews here on DSMtuners, if i can find the link i will post it
if you buy the catback system and header separate youll save some money..... like everyone one says stainless steel is stainless steel.... so no need to waste a grip for a name brand like i did. If you do go this route make sure to get a hi flow cat or resonator cause the stock wont bolt right up to the header
i bought the same thing for my 420a.. did not fit perfect.. there was a gap about a foot where either the cat would go or test pipe.. i just welded same size exhaust pipe
