FMIC, running hot, and lower ram air intake
Calan
DSM Wiseman
7,250
400
Jan 16, 2007
OKC, Oklahoma
Mounted my FMIC and now I'm running hot. Bought new slim fans which helps with idle, but when cruising around I'm still hot. So, I had this idea....
Has anyone ever used a lower "ram air" type scoop to force fresh air up between the IC and AC/Radiator? I'm guessing that the combination of lower flow + warmer air coming off the IC could be supplemented by adding a little fresh air. The only potential problem I see is turbulence which may actually reduce airflow even more... but I don't think this would be the case because it is much lower in volume than air coming through the IC, and should be at a lower velocity.
(I'm probably reinventing the wheel here, but haven't seen anything on it). I've got a fiberglass mockup in progress that I'll test ASAP, but wanted some opinions/feedback in the meantime.
Here is a rudimentary side-view diagram of what I have in mind.
Been done and helps, A LOT.
Also people take the "mouth" in the bumper and add in ducting there. Almost sectioning off the whole IC and RAD area altogether, and then also throwing in the "scoop" or "ram air" cooling. People have described this method almost cooling too much though, so be careful. But just the scoop should do you good!
  • For sale 2g 2g auto speedo gear
    2g auto. 97-99 speedo gear. From a GST trans. 29 teeth. Price is shipped Message 702-741-6987
  • Wanted 4G63 WTB 2G black top CAS
    Looking for.Shipped to CA 92707.Thanks.
    • AllanL
  • For sale 2g 2G Black Center Console ( all mounting points are intact )
    2G Black Center Console $70 + shipping & paypal fees* all mounting points intact * locking...
  • For sale 2g 2G OEM BOV Hose ( Great Condition )
    2G OEM BOV Hose $28 + shipping & paypal fees* this is the best condition one that I’ve got in...
