Fluidyne Radiator help
Prodigy
262
Nov 17, 2002
After installing my Fluidyne Radiator i let the car run for say about 30mins or so..After that i look at the stock gauge and its still right above the first line..Then i let it run for 10mins the fan comes on. But the gauge has not move??? Then i took it for a 5 min drive not hard just around the block..I get back home the gauge has not move again..So one it cant be the Tstat because the fan comes on at around 190?? Then i give it the real test i turn it on for 30mins with the air then it past the second line..Any help would be great thanks..
Originally posted by Mike1992
my cars temp always goes straight up to 12 o'clock, no higher, its normal to be past that line whats at about 11 o'clock
N/T must be different... 12 o'clock is past the overheating/red (you're screwed) range. Mine usually runs about the middle of the gauge, sometimes a little bit lower depending on the weather.
