Fluidampr Harmonic Damper
2slow4utsi
654
7
Mar 7, 2009
Eastpointe, Michigan
Is this overkill? I am putting together a 2.3L build and was wondering if this would be good to purchase or more of a "look what I have" piece. Are there any gains or benefits of running this over a stocker? Let me know.
-Danny
well for one it wont seperate like the stocker. that will happen no matter what. Two it will always be in balance because of the liquid in the part.
I know you need the stocker LOL I was just wondering if this is THAT much better and a good idea for my build. Also, I don't know whether to go 3 or 3.5 GM MAF. :[ Build will be 2.3L 6 bolt stroker with HX40 and ECM Link Shed some light please?
i use one. It will reduce the vibration and actually make your engine last longer. Your timing will be more stable also. You wont have to worry about your crank breaking as much as with a stock one.
If you have fun when you go to drive your car, (run it hard) you will probably go through a stocker once every 1.5 years. There are two GSX's in my family and the stocks just don't last. Spend the money and get the good one. You will save money in the long run.
I've hear/read somewhere that the stock (rubber) damper only dampens vibrations within a very small frequency range. However, the Fluidampr dampens ALL crankshaft vibrations due the use of a fluid damping material. An added benefit to its construction is that it will never separate and will probably outlast your car and engine.
I have a Fluidampr and for me, the added insurance and peace of mind was enough to convince me. Honestly, I haven't noticed ANY difference between the Fluidampr and the stock damper and I probably never will even as I continue increase the power. The engine doesn't run any smoother or rev any slower in my opinion.
Is is worth the added cost? Only you can determine that for yourself. But you're going to be spending thousands of dollars on your build, so what's a few hundred more spent on a Fluidampr? Whatever you do, stay away from the 3rd party OEM replacements like Dorman. There are too many people who have had bad experiences with them.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
