Fixed my stutter but new questions.
LA97GST
287
May 24, 2004
Slidell, Louisiana
Ok I just bought a new crew cab Z71 so the DSM got to go. I had the MBC set at 15-16 psi on my 14b and it bogged and stuttered. I was too lazy to really do to much work to it after I got my truck. Now that the car has to sell I finally got around to doing some work. For some reason my MBC wouldn't go any less than 15 psi. I suspected that the boost was too high and knocking like a motha so I put the stock BCS back on and took the MBC off. It is now boosting 9 psi and running smooth to redline. The car just has no power. I might be since I used to 16 psi. Is the 14b at 9 psi slower than the T25 at 9 psi because of the effiecency ranges? Should I put the T25 back on? How can I up the boost alittle to get some more power without going to 15 pounds? If I missed anything let me know.
There is a tiny tiny tiny one by TB I couldn't find. I know there should be none but this car is about to be sold. I just want to raise the boost to around 12 or 13 instead of this pathetic 9 right now. Should the MBC be able to drop below 15?
You are mistaken 2g's come around 9-10 psi stock. Most people can run 15 with no problem but I was knocking horribly so put the stock BCS back on. I'll try the MBC again.
