ECMlink first time running
shay4g63
143
Jul 24, 2011
miami, Florida
I recently got this 1993 awd tsi talon that has a 6 bolt swap in it..
Mods are:
engine:
Stock internals with L19 head studs
brand new knock sensor OEM
Fuel
255 wally hlp
8an fuel in to rail and afpr*which is set to 43psi unhooked*
1000cc ID injectors BRAND NEW
always 94 octane
exhaust:
fp cast manifold and new head studs
2.5" from 16g big back
new 02 sensor
Intake:
16g big just rebuilt,
2" ic piping heat wrapped near exhaust and kenetic fmic
SD set up*gm 3 bar and gm iat*
ecm boost ebc boost controller
cooling:
yokohama rad
new hoses
wetter water and coolant mixed
165 thermostate
Electronics:
ecm v3
electrionic boost contoller through ecmlink
innovative mtx-l wideband. Wired for loggin.
WILL BE ADDING METH ONCE I GET HER RUNNING GOOD WITHOUT METH. I JUST installed all these mods parts are BRAND NEW.. and i did a boost leak test and no leaks. also no PRE turbo or even POST turbo exhaust leaks.
Here is a idle,cruise and a couple pulls on LOW LOW LOW boost. I'm wondering why i'm knocking.. and what i could change.
