First time out with new setup (2.4 auto S256)
VETDRMS
340
21
Jun 1, 2006
Vancouver, Washington
The weather cleared for a near-perfect 60F day so I headed out to the opening day at Woodburn Dragstrip.
I found a 3" slice in the inner sidewall on one of my tires while checking everything the night before so I took the 17" BBS wheels from Evo and put them on the Talon.
The goal was to make some shakedown passes at low boost and low timing on pump to see how it shifts, converter, etc. It's a 50 mile drive so I didn't want to break anything by getting greedy before going back to E85.
I also finally weighted the heavy pig: it came in at a svelte 3600lbs with driver and a half tank of gas! OMG
First pass of the day was a 12.9 @ 110mph at 16psi and 9* of timing on a half tank of 92 and 2 gallons of VP110 (2.0s 60ft!). I had some persistent knock of about .4-1.1* through third gear so I took some timing out and richened it up a little.
The 60fts were terrible all day, it was lazy on spool and I was launching at 4000rpm with 12-15psi. Again, it was just to get some seat time and make sure everything was mechanically sound. I also have a pre-wastegate exhaust leak from the O2 housing (which is getting sent back to MAP this week).
Best pass of the day was a 12.701 @ 110mph with a blistering 1.9s 60ft (might as well be FWD with how soft its launching!). Average boost over the run is about 17psi, with 4* of timing for most of the run ramping up to 8-9*. It shifts out of first at 6500rpm and 7000rpm into 3rd and is trapping around 7100rpm (might need bigger tires when back on e85...).
Also, coolant temps were a little too high for pump, but I still have my winter 195F thermostat in so most passes started around 200F and ended around 206F, but were as high as 213F. OMG
All-in-all I am more than happy with how it went, it was a fun stress-free, problem-free day on the track with my Talon, can't get much better than that.
The log is attached from the 12.7 run, check out that timing curve! :p
Congrats man! Still need to find a time to come see this beast... Next time you head to the strip let me know, maybe Ill take a trip down to see you run! My car is still waiting on wiseco to get its crap straight and send me the right pistons... Anyhow, I am extremely excited to see what you do with her as things progress!
Its all about the seat time. THATS A WONDERFUL START LOL
4G64 + S256 + auto.... that sounds like the makings of a supremely delicious daily/street machine! And it's already near mid 12's, with less than optimal coolant temps and timing at such low boost pressure, very nice.
Thanks, this was a last minute trip, but I'll shoot you a PM next time we head out. I want to find another set of Evo BBS wheels to use on track days. It has been nice not waiting on parts, for once.
It was nice to be able to make some long pulls and make adjustments and go back and make repeatable pulls without the threat of law enforcement, or wildlife, or stupid people.
It does make a good daily driver. I've been commuting in the Evo, but my wife drives the Talon to go shopping/run errands, the current tune is wild enough for her, and conservative enough to where she can beat on it and not break anything. ROFL
