first time at the track.. not so good?
VPrime
802
3
Feb 5, 2006
Lonon, ON, Canada
today was my first time ever at the track, or even driving my car "hard"..
15.6302 was my best time.. I was thining my car would be quick enough to do atleast 15.0s.. so I am sure its my poor skills ROFL ..
I am pretty sure if i keep going I can lower my time, as by the end of the day I shaved a whole 1.2 seconds off my first run and it was my fastest time.
Mods:
-2.25(or 2.5?) RRE Hard UICP, with 1g BOV crushed
-Boost at 15ish psi
-Air filter+hard intake pipe
-ACT 2100 Clutch
-Bunch of junk in the trunk (10" sub, computer, spare tire, some tools..)
also here is my time slip...
Index: 15.70
Reaction Time: 0.6508
60 Ft: 2.1421(or 2.11 I cant make it out)
330ft: 6.4261
ET @ 594 ft: 9.3980
1/8 ET: 10.0481
1/8MPH: 69.21
1/4 ET: 15.6302
1\4 MPH: 85.86
Keep practicing and get your launch down and your times should drop. Im not going to say that they are bad times, but i think there is definately room for improvement.
Edit: Your 60 foot time doesnt look to bad, i would say practice shifting and running in the higher rpms.
definately boost leak test and compression test.
with my stock setup on my 95 tsi awd i did i think like 14.2 or 14.3 with a 1.65 60ft. i pretty much destroyed the clutch after launching it at like 6000RPM, but it took a lot of practice. the launch is one of the most important parts. a bad launch will screw up your whole run. right now i'm struggling to launch my car correctly with a BIG 16g and could only get a 13.8 with 2.1 60 fts @ 102mph. A better launch should net me low 13's at around 105mph. I also found out later that I was leaking boost after about 17-18psi.
Agreed you probably have a boost leak, and are in need of a tune up. your mph is low. Also driving practice always helps, maby racing next week-end at the forcepower BBQ for instance!
As everyone has stated. Your MPH is very low... 16 mph increase from 1/8 to quarter indicates there is a problem! I would think it would be at least 21-23mph gain from 1/8 to 1/4. I see that you had a lot of stuff in the trunk, and more then likely an easy 85-100 lbs. So there is a .10 right there.. Also, what kind of fuel level were you running at? What was the conditions of the day , and what elevation?
First time at the track is always not so good. Your ET was fine considering the power you were putting down. It's only going to get better :D Preform the above suggested, then pick up 5 MPH the next time out.
