General First start up Idle surge 1G
Yep, EPROM ECU. Serious case of capacitor leakage in the past and the repairs left off several of the SMD capacitors and failed to clean up all the corrosion damage. Missing heat sink clamp on the regulator pass and injector driver transistors.
Typical "professional" hack job.
Thank you for the info. I will most likely send it to ECMLINK since it is chipped and have repaired and LINK installed,
