finally found knock....what do you think
vkalloo
98
Aug 28, 2004
Ft Lauderdale, Florida
i now know the knocking sound is coming from my transmission. at low rpm it is very loud and can be heard with the windows up...down.....up w/ earmuff ...or down w/ earmuff. its not from the engine because when i depress the clutch the sound goes away.....revving engine now sound.....but the knock is from the tranny....in neutral i can hear it but not loud. help please :sosad:
1 pressure plate
2 throw out bearing
3 clutch disk
4 possible flywheel
got to pull the tranny to find out.
My transmission does the exact same thing. I've replaced the pressure plate, flywheel, throwout bearing and clutch disc and all the bolts were torqued to spec. I am also getting knock at all different rpm's but mostly low and mid. Could the transmission noise be causing the knock detection? I'd also like to know.
thought it was lifter tick....nope
rod knock.....nope
then i heard it coming only in gear and from the passenger side.
the noise if very very annoying
I am not sure if thats anything like what my 90 Talon turbo 5Sp FWD did last nite or not. My 'knocking", ticking, is with every tire revolution, and only in gear coasting downspeed. I was gonna be looking in the half shafts, but crawled under it this am and spun the tires by hand and can hear the noise every revolution, coming from the transfer case.Anybody had this, and how expensive a repair was it?( Correction) the noise is coming from where the two half shafts connect to tranny, or differential.
yeah it's starting to get to me now. it's loud as hell. if i drive by a wall or something the car sounds like bullets being fired. I was thinking about going with a new clutch. guy i bought the car from claims it's a 2100 hundred act but i don't know. anyway i would like to know what i should check for while doing this change. it sounds like marbles in can sounding noise and insanely loud at low rpm like 2000rpm or so while cruising and muffled but loud at high rpm. it is not from the engine, i know this so far. some people same bell housing and such. so if you could PLEASE please please help me..... thanks
