fic 1100cc injectors
SomeGoFast
6
Sep 5, 2015
West Harrison, Indiana
I have a set of fic 1100cc injectors which are high impedance from my 2jz part out. My question is, is it possible to use these in my 4g63? They are top feed just like the factory injectors and i know we need low impedance but can use high. Would i just need to order a different o ring kit or should i sell this set and buy another. Thanks Ryan
Sorry lost my mind there for a min. So is it possible to use these injectors? Should they drop right in or do i need a different o ring kit?
You may find the top section of the injector may need to be changed out, best place to ask is fic, tell them the situation and they can advise you 100% on what can be done
Ok thanks guys i just figured i would check to see if anyone on here knew or had done this before. Ill shoot them an email and find out. Thanks again Ryan
