Failed inspection, few quick suspension questions
endeffect0
544
Sep 19, 2006
Lancaster Area, Pennsylvania
I'm getting my car inspected by some local shop in my home town. It hasn't been on the road since 2002 and I expected some issues like this but I need to make a quick decision on what I can easily do my self this weekend and what i should pay to have done.
Left front lower ball joint is bad, so i need to replace the whole lower control arm. any tricks or special tools needed?
Left front hub/bearing. I probably am going to have the shop do this, doesn't seem like something i want to deal with.
Left rear suspension bushing on the outside of the upper arm is destroyed and needs to be replace... i never really looked at this part so i don't know what would be required to replace it.
I'm just looking for some quick insight as to the work involved in replacing these parts and any opinions on what i should do my self. I have no issues doing this work as long as I'm not going to need special tools or a press to do it...
so no special tools or presses to replace the rest bushings. thats good news.
For bushings, use a butane torch to heat the arm around the bushing and the bushing usually will either fall out or be easily tapped out with a hammer and a socket
  • Wanted 6 bolt NT water pipe
    • chrisman287
