"Extreme" Turbo Kit? (www.turbo-kits.com)
DeuceX
Mar 24, 2005
Lenoir, North Carolina
I came across this while looking for a turbo for a friend's Corolla...did some spot research here and couldn't track it down, and I've gotta head in to work. Here's the link: Turbo Kit I'll check back in when I get home. Apologize if someone's already found this, I don't have as much time to look it up as I usually do. Any info on this thing would be appreciated, its the first time I've ever seen it. Only kits I had seen prior to this for my N/T Eclipse are the Hahn and Star kits. Thanks, everyone!
I wouldnt go for it in my opinion, comes with a T25 (stock 2g turbo, very small) and on the side it says it works for the 420A and the 4G63. Just becuase of that im leary. You might as well go with the Star or Hahn kit. They are truly the only reputable "kits" out there. Or going for a custom kit is fun if you have the know how. Because you will get the parts you want and can save yourself some cash. I also recommend picking up the book "Maximum Boost" from your local book store, itll teach you a boat load on turbo charging yoru car and what all is required to do it correctly.
Almost $3k for a T25 kit? No way. NFW.
