Russell
- 0
- Feb 28, 2004
thunder bay,
Hello all,
I am going to be buying the Precision T & E SCM50 turbo from extreme psi this week, and was wondering what turbine sizes, and if the exhaust cutout should be ther, etc.. to go with
--ill be going with the .63 A/R
--Turbine Wheel im unsure of 76 wheel trim or 69 wheel trim, whats the difference which one is stage 2? stage 3? stage 4? stage 5?
--uncut or cut exhaust housing, i want to run 15 psi pump gas on the street or 20psi pump gas at the track, what is the difference between the 2
--ill be going with the heavy duty external gate
--ill be going with the install kit
and last but not least,
-- what way do i tell them to weld on the 90 degree intercooler elbow? left or right? (im guessing it should look like the t-25, facing left?)
thanks alot,
any other information on this turbo would be great, ive searched the fourms and read all i can about it,,, is there anyting else that i should know,, i have considered the agp setup, or RNR setup,, but i dont see the point just for an external wastegate, or am i wrong
cheers
thanks alot,
cheers
