GUTSI
- 71
- 28
- Nov 6, 2002
T.O.,
Hi everyone....Now here's a post to which I "somewhat" know the answer to
....HOWEVER, I'm posting it here in hopes of actually pin-pointing the problem (of course it's here cuz this is something that ONLY happens at the track)....
The cars' a 95 Talon TSi AWD Turbo: full exhaust,intake,upper/lower pipes,greddy bov...AND the Symborski shifter plate bushings (and BTW, a very decent mod that has improved shift and shift-feel
Stock boost (around 14 psi....no MBC yet) and the car ran a best of 14.6, and here's why:
I launch at 5500, slipping the clutch.....Shift into 2nd around 6500.....THEN, at around 6500 again, I try to go into 3rd...and grind! But it grinds fast (like a very short abrupt grind noise) and doesnt go in at all! And I've tried several times....I've even tried it gently....mashed the clutch, put it in softly, just wont go in....period! I have to really let the rpm's drop a bit, then it goes in, and hence the ridiculous 14.6 timeslip.
My 60ft times have been consistent 1.81....and I kept blowing away a slightly modded WRX( just intake and exhaust), but every time that it wouldn't go into 3rd, he beat me
and he finishes with a 14.2...
It's obvious I can propel this car into HIGH 13's, but flat 14's should be consistently easy....
Now, I know....synchros are probably worn (or wearing out, cuz it doesnt do it AT ALL during normal driving, OR if I punch it a little)...OR its the type of fluid: I'm currently using REDLINE Synthetic (could be part of the problem? Suggestions include replacing with a thicker fluid)....
I apologize bout the long post, but I thought i'd inform u guys in detail, and if there's someone out there with some positive feedback, I much appreciate it....
REMEMBER...it's not that it grinds going INTO 3rd, it grinds and wont go in....REALLY hurting my times at the track...PLS HELP!!
Thanks guys
....HOWEVER, I'm posting it here in hopes of actually pin-pointing the problem (of course it's here cuz this is something that ONLY happens at the track)....The cars' a 95 Talon TSi AWD Turbo: full exhaust,intake,upper/lower pipes,greddy bov...AND the Symborski shifter plate bushings (and BTW, a very decent mod that has improved shift and shift-feel
and he finishes with a 14.2...It's obvious I can propel this car into HIGH 13's, but flat 14's should be consistently easy....
Thanks guys
....Yes, I've heard that for the time being double-clutching will get it into gear....
