Exhaust help... Missing part
yayabago
36
Aug 31, 2012
Stickney, South Dakota
I have a 3" downpipe and bought 3" straight exhaust but it seems I am missing a small section right after the downpipe... I can give pictures if needed but was hoping someone has ran into this already for a quick answer on what needs to be bought.
Just take it to an exhaust shop and have them cut one of the pipes and add an extension ot it. That's probably the easiest and best way to fix it.
I'm assuming that would be where your catalytic converter is supposed to go, you can buy one from the dealer/ parts store (expensive) or buy a test pipe on eBay which would be much cheaper, or you could have a muffler shop weld a piece of pipe in there but then it would be a PITA to remove your exhaust
i was going to do that but that mean i gotta get a trailor and take it to em and trailor it back - so I am posting to see if the part could be purchased... easier and chaeper.
Thats a full 3inch turbo back.
You most likely didnt get a long enough downpipe. Best bet is to get a pipe welded on. And dont go to Autozone and get their off the shelf 3 inch pipe. They rust out rather quickly.
  • Wanted 6 bolt NT water pipe
    • chrisman287
