Exhaust hardware
IslanderTsi
236
Mar 15, 2006
charlottetown,
I am piecing together an exhaust. I picked up a downpipe off ebay but it didint come with any hardware or gaskets. What should I use for bolting it up to the o2 housing and the midpipe?
Also will most exhaust shops carry 2.5 and 3" 2 hole gaskets?
NAPA has a nice industrial 3 inch gasket b ut its like 12 bucks. Autozone, go in there wiht your dp or 02 housing and just ask to look through the gaskets and find one that matches thats what I do...Ill run donw and grap the part number of the one I use
Ok the top number is EG24044
The bottom one hightlighted in black is FP-60025
If your using the stock 02 housing this will be perfect.
i'm using 10wt bolts with crush washers and a nut to hold mine up. good heat and load bearing capability. go to Lowe's or whatever hardware store you have (Ace or Lowe's pref) and just pick up the size you need.
Cheap Option: Get some Hi-Temp RTV Silicone Gasket maker. I just used this stuff for my new cat because I got another smog due in a few months, so when I swap out the cat for smog, then I'll just use real gaskets when I put my hi-flow cat back in.
