Exhaust Bolt Oil Leaking
lilair30
Sep 5, 2004
Westland, Michigan
Today when i pulled in my driveway my engine started to smoke a lot....so it was leakin oil...but on the exhuast manifold, one of the middle bolts is missing...seemed like a stud and you screw on the bolt....well oil was comin out of there when car was on....whut is needed to be done? put new stud or bolt back in? change the gasket? i really dont know much but would help w/all ur input....btw its a 91 gsx....thnx for ne thin n everything.... :confused: :mad:
I'm guessing that it is the center bottom bolt that is missing. It runs right into an oil passage, and will leak from time to time. Just pick up a new stud and washer/nut. Clean the threads using a tap&die set. Then install the stud using some red RTV or locktite of some sort on the threads.
It should fix your problem.
