excessive heat, but not overheating
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
Ever since I got this car I've noticed an excessive amount of heat from the engine bay. I can feel it through the door defrost vents, and I'm pretty sure it's seeping through the firewall. When I pop the hood after even a short ride, the bay is extremely hot, more so than any of my previous DSMs. I replaced most of the cooling system last summer, and I have no overheating or loss of coolant. As the summer heats up, its becoming extremely uncomfortable. Feels like the heats on. Of course the ac compressor's shot and its not getting replaced any time soon. Any ideas?
G'day.
IMHO. Two things to check and do.
1. Check the control valve that supplies the heater in the car, it may be stuck open.
2. Get your exhaust manifold/dump/ and down to the turn at the front of the motor ceramic coated. It works a treat keeping heat in the exhaust.
http://www.jet-hot.com/
I had mine done on my rally VR4 here in Australia. Happy with it.
Cheers
Ross
well youll have no heater for your defrosters. I dont know if that safety feature means anything to you. that switch in the middle of your hvac that goes left to right controls outside air coming into the cabin. one side will allow heat from the core through the vents and the other will block it out. Thats why your feeling engine heat from your door vents. connect a scanner to your vehicle and check your sensors for over heating but i guarantee thats it.
I thought that may be the culprit, but I still feel heat no matter which position the lever's at. Is it possible the vent that the lever controls somehow came loose and isn't shutting properly? (As I believe our friend from down under suggested) Where the hell is it? I can't find it in the Haynes manual. When I flip the lever, I can hear a clunk from behind the glove box if that means anything, but I'm not going to start pulling apart the blower if I don't have to.
If you drop you glove box and stick your head back there, you can see the lever and wire that controls the heat/A/C temp setting. Mines always blew hot, turned out the wire had came lose so it was stuck on hot even when i tried to adjust, i reconnected the wire to the the lever and WALA it solved that issue.
OK so I seafoamed through the vacuum line the other day and a shitload of smoke came bellowing from beneath the heat shield. I've been planning to replace the manifold, and I assume its either leaking from the gasket or its cracked. I assume this is causing the excessive heat. Also, I've been experiencing low, semi sputtering idle ( hence the reason for seafoam) since I tried recharging the ac. Is this being caused by the header leak? My tps and IAC are good.
clean the radiator inside and out. straighten any bent fins. replace the thermostat and fluid. make sure fans are working at all temp ranges. dsms run a little warm under the hood anyway. you could also do a coolant system cleanout. there could be a bunch of gunk and scale inside impeding flow.
