Excessive Fuel Tank,pressure code p0443, correct part for fix?
brandnew161
215
Mar 30, 2009
Horseheads, New York
Since buying the car (previous owner had this problem too) I've noticed that when filling up the car with gas the fuel tank will bleed a lot of pressure when removing the fuel cap. I scanned the comp and the code is p0443; pretty sure it said something regarding the purge control solenoid. I removed the battery to check out what i was dealing with. First off the purge valve itself was cracked and in turn didnt work obviously. I went to the salvage yard and bought a new valve. Still the code p0443 is there after resetting the ecu. I went to advance auto and they pulled up a picture of the part I need. Now here's the thing, it doesnt look like what is under the hood currently. The picture of "purge solenoid" showed a small plastic solenoid/valve with an electrical connection and 3 vacuum ports. The same picture was also used when he looked up "purge valve". Did a newer product hit the market which integrates the purge valve and purge solenoid? If I still have excessive fuel tank pressure and the valve is good, the only other bad component would hopefully be the purge solenoid right? Finally, is the purge solenoid the same for FI and NA dsm's of the same model year?
Thanks for the help
-Bill
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
